New interface
Documents associated with scientific events
Sparse supernodal solver with low-rank compression for solving the frequency-domain Maxwell equations discretized by a high order HDG method
Abstract : In this talk, we present the use of PaStiX sparse direct solver in a Schwarz method for solving the frequencydomain Maxwell equations discretized by a high order HDG method. More precisely, the sparse solver is used to solve a system on sub-domains while iterative refinement is performed to get the global solution. Recently, low-rank compression have been added to PaStiX in order to reduce the time-to-solution or the memory footprint of the solver. The resulting low-rank solver can be used either as a direct solver at a lower accuracy or as a good preconditionner for iterative methods. We will investigate the use of low-rank compression for the frequency-domain Maxwell equations on large systems to experiment the compressibility of this equation.
Document type :
Complete list of metadata
Cited literature [1 references]  Display  Hide  Download
https://hal.inria.fr/hal-01660653
Contributor : Gregoire Pichon Connect in order to contact the contributor
Submitted on : Monday, December 11, 2017 - 11:18:55 AM
Last modification on : Friday, November 18, 2022 - 9:24:30 AM
File
slides.pdf
Identifiers
  • HAL Id : hal-01660653, version 1
Citation
Grégoire Pichon, Eric Darve, Mathieu Faverge, Stéphane Lanteri, Pierre Ramet, et al.. Sparse supernodal solver with low-rank compression for solving the frequency-domain Maxwell equations discretized by a high order HDG method. Journées jeunes chercheur-e-s - Résolution de problèmes d’ondes harmoniques de grande taille, Nov 2017, PARIS, France. pp.1-55, 2017. ⟨hal-01660653⟩
Share
Metrics
Record views
239
Files downloads
39
