Periodic motions of coupled impact oscillators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2018
We study the existence and stability of time-periodic oscillations in a chain of coupled impact oscillators, for rigid impacts without energy dissipation. We formulate the search of periodic solutions as a boundary value problem incorporating unilateral constraints. This problem is solved analytically in the vicinity of the uncoupled limit and numerically for larger coupling constants. Different solution branches corresponding to nonlinear localized modes (breathers) and normal modes are computed.
James_Acary_Perignon.pdf (5.42 Mo) Télécharger le fichier
hal-01660891 , version 1 (11-12-2017)
Guillaume James, Vincent Acary, Franck Pérignon. Periodic motions of coupled impact oscillators. Remco Leine; Vincent Acary; Olivier Brüls. Advanced Topics in Nonsmooth Dynamics, Transactions of the European Network for Nonsmooth Dynamics, Springer International Publishing, pp.93-134, 2018, 978-3-319-75971-5. ⟨10.1007/978-3-319-75972-2_3⟩. ⟨hal-01660891⟩
269 Consultations
142 Téléchargements
