From dance to touch: movement qualities for interaction design
In this paper we present a novel approach for the
design of large-scale tactile ludic interfaces. Our
contribution is a non task-oriented interaction
technique based on modern dance for the creation of
aesthetically pleasant large-scale tactile interfaces. This
approach is based on dance movement qualities applied
to touch interaction allowing for natural gestures in
large touch displays. We used specific movements from
a choreographic glossary and developed a robust
movement quality recognition process. To illustrate our
approach, we propose a media installation called A light
touch, where touch is used to control a light spot.
