Factorization and Exact Evaluation of the Source-Terminal Diameter-Constrained Reliability - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Networks Année : 2017
In classical network reliability, the system under study is a network with perfect nodes and imperfect links that fail randomly and In classical network reliability, the system under study is a network with perfect nodes and imperfect links that fail randomly and independently.. The probability that a given subset K of terminal nodes belongs to the same connected component is called classical or K-Terminal reliability. Although (and because) the classical reliability computation belongs to the class of N P-Hard problems, the literature offers many methods for this purpose, given the importance of the models. This article deals with diameter-constrained reliability, where terminal nodes are further required to be connected by d hops or fewer (d is a given strictly positive parameter of the metric called its diameter). This metric was defined in 2001, inspired by delay-sensitive applications in telecommunications. Factorization theory is fundamental for the classical network reliability evaluation, and today it is a mature area. However, its extension to the diameter-constrained context requires at least the recognition of irrelevant links, which is an open problem. In this paper, irrelevant links are efficiently determined in the most used case, where |K| = 2, thus providing a first step towards a Factorization theory in diameter-constrained reliability. We also analyze the metric in series-parallel and composition graphs. The article closes with a Factoring algorithm and a discussion of trends for future work.
Networks2017-new.pdf (305.13 Ko) Télécharger le fichier
hal-01663508 , version 1 (14-12-2017)
Eduardo Canale, Pablo Romero, Gerardo Rubino. Factorization and Exact Evaluation of the Source-Terminal Diameter-Constrained Reliability. Networks, 2017, Special Issue on Design of Resilient Communication Networks, 70 (4), pp.283-291. ⟨10.1002/net.21780⟩. ⟨hal-01663508⟩
401 Consultations
168 Téléchargements
