Generic Programming in OCAML - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
We present a library for generic programming in OCAML, adapting some techniques borrowed from other functional languages. The library makes use of three recent additions to OCAML: generalised abstract datatypes are essential to reflect types, extensible variants allow this reflection to be open for new additions, and extension points provide syntactic sugar and generate boiler plate code that simplify the use of the library. The building blocks of the library can be used to support many approaches to generic programming through the concept of view. Generic traversals are implemented on top of the library and provide powerful combinators to write concise definitions of recursive functions over complex tree types. Our case study is a type-safe deserialization function that respects type abstraction.
generic.submitted.pdf (312.91 Ko) Télécharger le fichier
hal-01664286 , version 1 (14-12-2017)
  • HAL Id : hal-01664286 , version 1
Florent Balestrieri, Michel Mauny. Generic Programming in OCAML. 2017. ⟨hal-01664286⟩
120 Consultations
1066 Téléchargements
