A new class of uniformly accurate numerical schemes for highly oscillatory evolution equations
We introduce a new methodology to design uniformly accurate methods for oscil-latory evolution equations. The targeted models are envisaged in a wide spectrum of regimes, from non-stiff to highly-oscillatory. Thanks to an averaging transformation, the stiffness of the problem is softened, allowing for standard schemes to retain their usual orders of convergence. Overall, high-order numerical approximations are obtained with errors and at a cost independent of the regime.
