Reports
Report on fully coupled data assimilation in simplified systems with implications for Earth system reanalysis
Arthur Vidard 1 Rémi Pellerej 1 Florian Lemarié 1
1 AIRSEA - Mathematics and computing applied to oceanic and atmospheric flows
Inria Grenoble - Rhône-Alpes, Grenoble INP - Institut polytechnique de Grenoble - Grenoble Institute of Technology, UGA [2016-2019] - Université Grenoble Alpes [2016-2019], LJK - Laboratoire Jean Kuntzmann
Abstract : This report describes the Inria contribution to WP2 regarding a study of coupled data assimilation algorithms applied to academic models. This task was twofold: 1. Propose and study new coupled variational data assimilation algorithms. 2. Create a stand-alone coupled single column model (SCM) that mimics the ocean atmosphere behaviour and that can be used to validate the algorithms proposed in 1. Regarding subtask 1, a focus was made on ways to explicitly account for model coupling in the varia-tional optimisation problem, either as a strong contraint or as a weak constraint, or as a combination of both. It is then applied to both linear and non linear coupled problems, and leads to the conclusion that it does bring some noticeable benefit, but at a cost, both in time of development and computing time. The cost-benefit ratio has therefore to be studied for each given application. The coupled SCM has been developed in Fortran and interfaced with the OOPS data assimilation framework. It is documented in this report and a reference test case is given, so that it can be reused by partners of the project and beyond.
Complete list of metadata
Cited literature [17 references]  Display  Hide  Download
https://hal.inria.fr/hal-01667509
Contributor : Arthur Vidard Connect in order to contact the contributor
Submitted on : Tuesday, December 19, 2017 - 6:22:43 PM
Last modification on : Monday, November 8, 2021 - 9:58:01 AM
File
delivrable_D2.11.pdf
Identifiers
  • HAL Id : hal-01667509, version 1
Collections
Citation
Arthur Vidard, Rémi Pellerej, Florian Lemarié. Report on fully coupled data assimilation in simplified systems with implications for Earth system reanalysis. [Research Report] Inria Grenoble Rhône-Alpes. 2017. ⟨hal-01667509⟩
Share
Metrics
Les métriques sont temporairement indisponibles
