Recent Advances in Matrix Partitioning for Parallel Computing on Heterogeneous Platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2017
The problem of partitioning a matrix into a set of sub-matrices has received increased attention recently and is crucial when considering dense linear algebra and kernels with similar communication patterns on heterogeneous platforms. The problem of load balancing and minimizing communication is traditionally reducible to an optimization problem that involves partitioning a square into rectangles. This problem has been proven to be NP-Complete for an arbitrary number of partitions. In this paper, we present recent approaches that relax the restriction that all partitions be rectangles. The first approach uses an original mathematical technique to find the exact optimal partitioning. Due to the complexity of the technique, it has been developed for a small number of partitions only. However, even at a small scale, the optimal partitions found by this approach are often non-rectangular and sometimes non-intuitive. The second approach is the study of approximate partitioning methods by recursive partitioning algorithms. In particular we use the work on optimal partitioning to improve pre-existing algorithms. In this paper we discuss the different perspectives it opens and present two algorithms, SNRPP which is a sqrt(3/2) approximation, and NRPP which is a 2/sqrt(3) approximation. While sub-optimal, this approach works for an arbitrary number of partitions. We use the first exact approach to analyse how close to the known optimal solutions the NRRP algorithm is for small numbers of partitions.
paper.pdf (374.58 Ko) Télécharger le fichier
hal-01670672 , version 1 (21-12-2017)
hal-01670672 , version 2 (11-05-2018)
  • HAL Id : hal-01670672 , version 1
Olivier Beaumont, Brett A. Becker, Ashley Deflumere, Lionel Eyraud-Dubois, Thomas Lambert, et al.. Recent Advances in Matrix Partitioning for Parallel Computing on Heterogeneous Platforms. 2017. ⟨hal-01670672v1⟩
544 Consultations
660 Téléchargements
