SmartInspect: Smart Contract Inspection Technical Report - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Smart contracts are embedded procedures stored with the data they act upon. Debugging deployed Smart Contracts is a difficult task since once deployed, the code cannot be reexecuted and inspecting a simple attribute is not easily possible because data is encoded. In this technical report, we present SmartInspect to address the lack of inspectability of a deployed contract. Our solution analyses the contract state by using decompilation techniques and a mirror-based architecture to represent the object responsible for interpreting the contract state. SmartInspect allows developers and also end-users of a contract to better visualize and understand the contract stored state without needing to redeploy, nor develop any ad-hoc code.
tech_report.pdf (923.19 Ko) Télécharger le fichier
hal-01671196 , version 1 (22-12-2017)
  • HAL Id : hal-01671196 , version 1
Santiago Bragagnolo, Henrique S C Rocha, Marcus Denker, Stéphane Ducasse. SmartInspect: Smart Contract Inspection Technical Report. [Research Report] Inria Lille. 2017. ⟨hal-01671196⟩
442 Consultations
249 Téléchargements
