A Refinement Approach for the Reuse of Privacy Risk Analysis Results
Réutilisation de résultats d'analyse de risques en vie privée par raffinements
The objective of this paper is to improve the cost effectiveness of privacy impact assessments through (1) a more systematic approach , (2) a better integration with privacy by design and (3) enhanced reusability. We present a three-tier process including a generic privacy risk analysis depending on the specifications of the system and two refinements based on the architecture and the deployment context respectively. We illustrate our approach with the design of a biometric access control system.
Ordinateur et société [cs.CY]
