Refinement indicators for estimating hydrogeologic parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inverse Problems in Science and Engineering Année : 2019
We identify simultaneously the hydraulic transmissivity and the storage coefficient in a ground water flow governed by a linear parabolic equation. Both coefficients are assumed to be functions which are piecewise constant in space and constant in time. Therefore the unknowns are the coefficient values as well as the geometry of the zones where these parameters are constant. The identification problem is formulated as the minimization of a misfit least-square function. Using refinement indicators, we refine the parameterization locally and iteratively. We distinguish the cases where the two parameters have the same parameterization or different parameterizations.
articlepreprint.pdf (3.37 Mo) Télécharger le fichier
hal-01674486 , version 1 (02-01-2018)
M-H. Riahi, Hend Ben Ameur, Jérôme Jaffré, Rachida Bouhlila. Refinement indicators for estimating hydrogeologic parameters. Inverse Problems in Science and Engineering, 2019, 27 (3), pp.317-339. ⟨10.1080/17415977.2018.1460366⟩. ⟨hal-01674486⟩
283 Consultations
142 Téléchargements
