Exploiting Execution Dynamics in Timing Analysis Using Job Sequences - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Design & Test Année : 2017
Worst case design as needed for critical systems usually resorts to established methods for worst case response time analysis which rely on the worst case execution time of tasks and the minimum temporal distance between task activations. The result is often very pessimistic when compared to the real worst case load. Many feasible designs are therefore rejected under such analyses. Using worst case models based on job sequences rather than single jobs leads to less pessimistic results and makes worst case design more practical. This paper outlines existing modeling and analysis techniques which are based on job sequences and refers to several examples from automotive design where great benefits were demonstrated.
DesignAndTest17.pdf (840.39 Ko) Télécharger le fichier
hal-01674751 , version 1 (03-01-2018)
Leonie Ahrendts, Sophie Quinton, Rolf Ernst. Exploiting Execution Dynamics in Timing Analysis Using Job Sequences. IEEE Design & Test, 2017, 35 (4), pp.16-22. ⟨10.1109/MDAT.2017.2746638⟩. ⟨hal-01674751⟩
109 Consultations
110 Téléchargements
