Achieving the Sensing, Smart and Sustainable “Everything” - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The vast diversity of current sensing devices and mechanisms enable the creation of data-rich environments which gives the opportunity to create smart systems. The smartness of systems must transcend individual interests and fulfill collective aspirations and environmental needs. Therefore, new products, processes, enterprises, communities and any kind of systems must be envisioned as Sensing, Smart and Sustainable (S3). This paper discusses the trends and challenges for S3 applied to everything. Furthermore, it suggests that the knowledge produced in the field of collaborative networks might be used to leverage the S3 capabilities.
455531_1_En_51_Chapter.pdf (1.05 Mo) Télécharger le fichier
hal-01674904 , version 1 (03-01-2018)
Paternité
Dante Chavarría-Barrientos, Luis M. Camarinha-Matos, Arturo Molina. Achieving the Sensing, Smart and Sustainable “Everything”. 18th Working Conference on Virtual Enterprises (PROVE), Sep 2017, Vicenza, Italy. pp.575-588, ⟨10.1007/978-3-319-65151-4_51⟩. ⟨hal-01674904⟩
52 Consultations
121 Téléchargements
