Stationary Distribution of Waiting Time in MAP/G/1/N Queueing System with LIFO Service Discipline - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider single server queueing system with a finite buffer, MAP input and independent generally distributed service times. Customers are selected for the service in accordance with the LIFO (Last In – First Out) service discipline. It is well known that stationary distribution of the number of customers in such a system coincides with the corresponding distribution in the system with FIFO (First In – First Out) discipline which has been studied in the literature early. In the present research we focus on investigating the stationary distribution of waiting (sojourn) time in the system.
453598_1_En_5_Chapter.pdf (274.61 Ko) Télécharger le fichier
hal-01675436 , version 1 (04-01-2018)
Paternité
Alexander Dudin, Valentina Klimenok, Konstantin Samouylov. Stationary Distribution of Waiting Time in MAP/G/1/N Queueing System with LIFO Service Discipline. 15th International Conference on Wired/Wireless Internet Communication (WWIC), Jun 2017, St. Petersburg, Russia. pp.50-61, ⟨10.1007/978-3-319-61382-6_5⟩. ⟨hal-01675436⟩
183 Consultations
53 Téléchargements
