A Mobility-Aware Channel Allocation Strategy for Clustered Ad hoc Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a mobility-aware channel allocation strategy for clustered ad hoc network. Our main novelty is to consider the user mobility associated with traffic history and node popularity to guide the channel allocation process, while quickly responding to changes in the network topology. In our performance evaluation and contrarily to related works, we use a realistic mobility model based on user behavior and consider channels with largest spectral distance as well as the smallest number of occurrences. Obtained results show that our strategy presents throughput 15,43 % and 17,74% higher when compared with RANDOM and LD algorithms respectively, and lower overhead when compared with TABU algorithm.
261-95756-review.pdf (221.55 Ko) Télécharger le fichier
hal-01676499 , version 1 (05-01-2018)
  • HAL Id : hal-01676499 , version 1
Roni F Shigueta, Mauro Fonseca, Aline Carneiro Viana. A Mobility-Aware Channel Allocation Strategy for Clustered Ad hoc Network. VTC2017-Spring - 2017 IEEE 85th Vehicular Technology Conference, Jun 2017, Sydney, Australia. ⟨hal-01676499⟩
122 Consultations
149 Téléchargements
