New interface
Journal articles
Synchronization of stochastic mean field networks of Hodgkin-Huxley neurons with noisy channels
Abstract : In this work we are interested in a mathematical model for the collective behavior of a fully connected network of finitely many neurons when their number and when time go to infinity. We assume that every neuron follows a stochastic version of the Hodgkin-Huxley model, and that pairs of neurons interact through both electrical and chemical synapses, the global connectivity being of mean field type. When the leak conductance is strictly positive, we prove that if the initial voltages are uniformly bounded and the electrical interaction between neurons is strong enough, then, uniformly in the number of neurons, the whole system synchronizes exponentially fast as time goes to infinity, up to some error controlled by (and vanishing with) the channels noise level. Moreover, we prove that if the random initial condition is exchangeable, on every bounded time interval the propagation of chaos property for this system holds (regardless of the interaction intensities). Combining these results, we deduce that the nonlinear McKean-Vlasov equation describing an infinite network of such neurons concentrates, as times goes to infinity, around the dynamics of a single Hodgkin-Huxley neuron with a chemical neurotransmitter channel. Our results are illustrated and complemented with numerical simulations.
Document type :
Journal articles
Complete list of metadata
Cited literature [52 references]  Display  Hide  Download
https://hal.inria.fr/hal-01678710
Contributor : Héctor Olivero Connect in order to contact the contributor
Submitted on : Friday, December 28, 2018 - 3:02:11 AM
Last modification on : Friday, July 8, 2022 - 10:05:54 AM
File
Synchronization_Mean_Field_HH_...
Identifiers
Citation
Mireille Bossy, Joaquin Fontbona, Héctor Olivero Quinteros. Synchronization of stochastic mean field networks of Hodgkin-Huxley neurons with noisy channels. Journal of Mathematical Biology, 2019, ⟨10.1007/s00285-019-01326-7⟩. ⟨hal-01678710v3⟩
Share
Metrics
Record views
583
Files downloads
375
