Refining the Specification FSM When Deriving Test Suites w.r.t. the Reduction Relation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Aleksandr Tvardovskii
  • Fonction : Auteur
  • PersonId : 1026265
Finite State Machines (FSMs) are widely used when deriving tests for components of discrete event systems. In general, the specification FSM can be nondeterministic and in this case, a test suite with the guaranteed fault coverage is derived with respect to the reduction relation. However, when deriving such tests for nondeterministic FSMs, the existing methods return rather long test suites which cannot be used for real systems. In order to shorten a test suite, the set of possible implementation FSMs can be reduced. We present an approach for deriving shorter test suites for nondeterministic FSMs with respect to the reduction relation via refining the specification FSM.
449632_1_En_22_Chapter.pdf (370.31 Ko) Télécharger le fichier
hal-01678992 , version 1 (09-01-2018)
Paternité
Aleksandr Tvardovskii. Refining the Specification FSM When Deriving Test Suites w.r.t. the Reduction Relation. 29th IFIP International Conference on Testing Software and Systems (ICTSS), Oct 2017, St. Petersburg, Russia. pp.333-339, ⟨10.1007/978-3-319-67549-7_22⟩. ⟨hal-01678992⟩
55 Consultations
71 Téléchargements
