Design Guidelines for Exploring Relationships in a Connected Big Data Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jaison Jacob
  • Fonction : Auteur
  • PersonId : 1026411
Santhosh Rao
  • Fonction : Auteur
  • PersonId : 1026412
Reimagining the ‘SAP Investigative Case Management’ frame-work from a log-based register of events to a direct interaction environment with the possibility to search, explore relationships between multiple entities in one or more cases/incidents. This case study is about our approach in conceptualizing a generic network visualization method by deconstructing the existing data models. We devised a set of guidelines that can be employed to represent a large number of entities with the intention of examining their relationships.
421765_1_En_27_Chapter.pdf (94.46 Ko) Télécharger le fichier
hal-01679824 , version 1 (10-01-2018)
Paternité
Jaison Jacob, Santhosh Rao. Design Guidelines for Exploring Relationships in a Connected Big Data Environment. 16th IFIP Conference on Human-Computer Interaction (INTERACT), Sep 2017, Bombay, India. pp.348-351, ⟨10.1007/978-3-319-68059-0_27⟩. ⟨hal-01679824⟩
42 Consultations
67 Téléchargements
