Decoding Methods in LED-to-Smartphone Bidirectional Communication for the IoT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
The use of visible light for bidirectional communication between regular smartphones and the small LEDs integrated in most consumer electronics nowadays raises new challenges. In this paper, we enhance the state of the art with an efficient image processing algorithm to accurately detect the LEDs and decode their signal in real time. To enable flash-to-LED communication on non-rooted smartphones, we propose encoding and decoding methods that cope with the inaccurate flashlight clock rate.
lifi-congress18.pdf (8 Mo) Télécharger le fichier
hal-01683629 , version 1 (14-01-2018)
Alexis Duque, Razvan Stanica, Hervé Rivano, Adrien Desportes. Decoding Methods in LED-to-Smartphone Bidirectional Communication for the IoT. Global LiFi Congress - 1st edition, Feb 2018, Paris, France. pp.1-6, ⟨10.23919/GLC.2018.8319118⟩. ⟨hal-01683629⟩
370 Consultations
1479 Téléchargements
