Understanding Trustworthy Service Level Agreements: Open Problems and Existing Solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Yudhistira Nugraha
  • Fonction : Auteur
  • PersonId : 1026589
Andrew Martin
  • Fonction : Auteur
  • PersonId : 1008923
Security has been considered for decades as a possible attribute in service level agreements (SLAs). However, the formulation of security properties has not been expressed in such concrete terms in SLA contexts because security is a process, not a product. Consequently, security properties, such as data confidentiality, integrity and availability have been overlooked in SLA contexts. This paper aims to identify open problems and existing solutions in the context of incorporating security properties into SLA contexts. First, we provide an overview of system assurance of which trustworthy SLAs can be considered as alternative assurance technique in the context of service provisioning. Then, we describe the notion of trustworthy SLAs and discuss possible security properties that can be potentially used in SLA contexts. Finally, we present some open research problems for the incorporation of security capabilities into SLA contexts to establish trust between the customer and service provider. This study identifies needs for developing a trustworthy SLA capability framework to formulate discrete levels of assurance which are believed to be capable of preserving data confidentiality, integrity and availability in SLAs as trust-enhancing instruments.
paper5.pdf (288.11 Ko) Télécharger le fichier
hal-01684231 , version 1 (15-01-2018)
Paternité
  • HAL Id : hal-01684231 , version 1
Yudhistira Nugraha, Andrew Martin. Understanding Trustworthy Service Level Agreements: Open Problems and Existing Solutions. International Workshop on Open Problems in Network Security (iNetSec), May 2017, Rome, Italy. pp.54-70. ⟨hal-01684231⟩
178 Consultations
419 Téléchargements
