Identification of Access Control Policy Sentences from Natural Language Policy Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Masoud Narouei
  • Fonction : Auteur
  • PersonId : 999038
Hamed Khanpour
  • Fonction : Auteur
  • PersonId : 1026644
Hassan Takabi
  • Fonction : Auteur
  • PersonId : 1026645
Access control mechanisms are a necessary and crucial design element to any application’s security. There are a plethora of accepted access control models in the information security realm. However, attribute-based access control (ABAC) has been proposed as a general model that could overcome the limitations of the dominant access control models (i.e., role-based access control) while unifying their advantages. One issue with migrating to an ABAC model is the information that needs to be encoded in the model is typically buried within existing natural language artifacts, hence difficult to interpret. This requires processing natural language documents and extracting policies from those documents. Software requirements and policy documents are the main sources of declaring organizational policies, but they are often huge and consist of a lot of general descriptive sentences that lack any access control content. Manually processing these documents to extract policies and then using them to build a model is a laborious and expensive process. This paper is the first step towards a new policy engineering approach for ABAC by processing policy documents and identifying access control contents. We take advantage of multiple natural language processing techniques including pointwise mutual information to identify access control policy sentences within natural language documents. We evaluate our approach on documents from different domains including conference management, education, and healthcare. Our methodology effectively identifies policy sentences with an average recall and precision of 90% on all datasets, which bested the state-of-the-art by 5%.
453481_1_En_5_Chapter.pdf (379 Ko) Télécharger le fichier
hal-01684368 , version 1 (15-01-2018)
Paternité
Masoud Narouei, Hamed Khanpour, Hassan Takabi. Identification of Access Control Policy Sentences from Natural Language Policy Documents. 31th IFIP Annual Conference on Data and Applications Security and Privacy (DBSEC), Jul 2017, Philadelphia, PA, United States. pp.82-100, ⟨10.1007/978-3-319-61176-1_5⟩. ⟨hal-01684368⟩
99 Consultations
227 Téléchargements
