Theoretical studies of the spin coating process for the deposition of polymer-based Maxwellian liquids - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Microelectronic Engineering Année : 2010
This paper deals with the study of spin coating processes for the deposition of polysiloxane-based thin films. Specific developments are proposed in order to adapt the hydrodynamic laws theory to the spin coating of Maxwellian liquids. Theoretical and experimental results are compared, evidencing a good fit and enabling to define the Maxwellian law for the studied polysiloxane polymer. Finally, the theoretical developments are successfully extended to the BCB 4026 and SU-8 3050 photosensitive resins.
paper_spincoating.pdf (1.11 Mo) Télécharger le fichier
hal-01687852 , version 1 (18-01-2018)
Pierre Temple-Boyer, Laurent Mazenq, Jean-Baptiste Doucet, Véronique Conédéra, Benoit Torbiero, et al.. Theoretical studies of the spin coating process for the deposition of polymer-based Maxwellian liquids. Microelectronic Engineering, 2010, 87 (2), pp.163-166. ⟨10.1016/j.mee.2009.06.030⟩. ⟨hal-01687852⟩
167 Consultations
45 Téléchargements
