Quadratic Optimal Control of Linear Complementarity Systems: First order necessary conditions and numerical analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Commande optimale quadratique des Systèmes de Complémentarité Linéaire : conditions nécessaires du premier ordre, analyse numérique
This article is dedicated to the analysis of quadratic optimal control of linear complementarity systems (LCS), which are a class of strongly nonlinear and nonsmooth dynamical systems. Necessary first-order conditions are derived, that take the form of an LCS with inequality constraints, hence are numerically tractable. Then two numerical solvers are proposed, for the direct and the indirect approaches. They take advantage of MPEC solvers for computations. Numerical examples illustrate the theoretical developments and demonstrate the efficiency of the approach.
expl.pdf (1.75 Mo) Télécharger le fichier
hal-01690400 , version 1 (23-01-2018)
hal-01690400 , version 2 (23-01-2018)
hal-01690400 , version 3 (18-04-2018)
  • HAL Id : hal-01690400 , version 1
Alexandre Vieira, Bernard Brogliato, Christophe Prieur. Quadratic Optimal Control of Linear Complementarity Systems: First order necessary conditions and numerical analysis. 2018. ⟨hal-01690400v1⟩
574 Consultations
918 Téléchargements
