Fast Bayesian Network Structure Learning using Quasi-Determinism Screening - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Learning the structure of Bayesian networks from data is a NP-Hard problem that involves optimization over a super-exponential sized space. In this work, we show that in most real life datasets, a number of the arcs contained in the final structure can be pre-screened at low computational cost with a limited impact on the global graph score. We formalize the identification of these arcs via the notion of quasi-determinism, and propose an associated algorithm that narrows the structure learning task down to a subset of the original variables. We show, on diverse benchmark datasets, that this algorithm exhibits a significant decrease in computational time and complexity for only a little decrease in performance score.
FastBNSL_V2 2.pdf (343.15 Ko) Télécharger le fichier
hal-01691217 , version 1 (23-01-2018)
hal-01691217 , version 2 (24-01-2018)
hal-01691217 , version 3 (12-03-2018)
hal-01691217 , version 4 (04-01-2019)
  • HAL Id : hal-01691217 , version 3
Thibaud Rahier, Sylvain Marié, Stéphane Girard, Florence Forbes. Fast Bayesian Network Structure Learning using Quasi-Determinism Screening. 2018. ⟨hal-01691217v3⟩
717 Consultations
591 Téléchargements
