How to Design a Program Repair Bot? Insights from the Repairnator Project - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Program repair research has made tremendous progress over the last few years, and software development bots are now being invented to help developers gain productivity. In this paper, we investigate the concept of a " program repair bot " and present Repairnator. The Repairnator bot is an autonomous agent that constantly monitors test failures, reproduces bugs, and runs program repair tools against each reproduced bug. If a patch is found, Repairnator bot reports it to the developers. At the time of writing, Repairnator uses three different program repair systems and has been operating since February 2017. In total, it has studied 11 317 test failures over 1 609 open-source software projects hosted on GitHub, and has generated patches for 17 different bugs. Over months, we hit a number of hard technical challenges and had to make various design and engineering decisions. This gives us a unique experience in this area. In this paper, we reflect upon Repairnator in order to share this knowledge with the automatic program repair community.
SEIP_63_Camera-Ready-no-copyright.pdf (780.95 Ko) Télécharger le fichier
hal-01691496 , version 1 (24-01-2018)
hal-01691496 , version 2 (30-01-2018)
hal-01691496 , version 3 (08-02-2018)
Simon Urli, Zhongxing Yu, Lionel Seinturier, Martin Monperrus. How to Design a Program Repair Bot? Insights from the Repairnator Project. 40th International Conference on Software Engineering, Track Software Engineering in Practice, May 2018, Gothenburg, Sweden. pp.95-104, ⟨10.1145/3183519.3183540⟩. ⟨hal-01691496v3⟩
797 Consultations
3587 Téléchargements
