Co-Design and Verification of an Available File System - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Distributed file systems play a vital role in large-scale enterprise services. However, the designer of a distributed file system faces a vexing choice between strong consistency and asynchronous replica-tion. The former supports a standard sequential model by synchronising operations, but is slow and fragile. The latter is highly available and responsive, but exposes users to concurrency anomalies. In this paper, we describe a rigorous and general approach to navigating this trade-off by leveraging static verification tools that allow to verify different file system designs. We show that common file system operations can run concurrently without synchronisation, while still retaining a semantics reasonably similar to Posix hierarchical structure. The one exception is the move operation, for which we prove that, unless synchronised, it will have an anomalous behaviour.
VMCAI-2018-filesys.pdf (534.96 Ko) Télécharger le fichier
hal-01696263 , version 1 (30-01-2018)
Mahsa Najafzadeh, Marc Shapiro, Patrick Eugster. Co-Design and Verification of an Available File System. VMCAI 2018 - International Conference on Verification, Model Checking, and Abstract Interpretation, Jan 2018, Los Angeles, CA, United States. pp.358-381, ⟨10.1007/978-3-319-73721-8_17⟩. ⟨hal-01696263⟩
259 Consultations
220 Téléchargements
