Synchronized switch harvesting applied to piezoelectric flags - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Smart Materials and Structures Année : 2016
In this article the energy transfer between a flow and a fluttering piezoelectric plate is investigated. In particular, the benefits of the use of a synchronized switch harvesting on inductor (SSHI) circuit are studied. Both wind tunnel experiments and numerical simulations are conducted in order to analyze the influence of the switching process on the dynamics and the efficiency of the system. Numerical simulations consist of a weakly nonlinear model of a plate in axial flow equipped with a single pair of piezoelectric patches, discretized using a Galerkin method where basis functions are the modes of the plate in vacuum. The discretized model is then integrated in time. The results presented in this paper show that a significant improvement of the harvested energy can be obtained using SSHI circuits compared to basic resistive circuits. It is also shown that for strongly coupled systems, the switching process inherent to he SSHI circuit has a significant impact on the dynamics of the flag, which tends to decrease the relative efficiency gain Q1 .
smsaa29fcp8.pdf (725.33 Ko) Télécharger le fichier
hal-01697480 , version 1 (07-12-2016)
hal-01697480 , version 2 (31-01-2018)
Miguel Pineirua, Sébastien Michelin, Dejan Vasic, Olivier Doaré. Synchronized switch harvesting applied to piezoelectric flags. Smart Materials and Structures, 2016, ⟨10.1088/0964-1726/25/8/085004⟩. ⟨hal-01697480v2⟩
543 Consultations
698 Téléchargements
