The MHM Method for the Helmholtz Equation - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
Wave propagation in heterogeneous media is accurately approximated on coarse meshes through a novel multiscale finite element method. Such a numerical method originates from the primal hybridization of the Helmholtz equation wherein the continuity of the pressure is released on the skeleton of a partition. As a result, the method is driven by the face degree of freedoms defined on faces of the partition, and independent local problems are responsible for the multiscale basis function computation. A two-level version of the method is also proposed in the case the basis functions are not promptly available. Well-posedness and a best approximation result is established for the one-and two-level MHM methods. Also, the MHM method is proved to be super convergent and is shown to recover other numerical methods. We assess theoretical results through a sequence of numerical tests.
paper_mhm.pdf (1.52 Mo) Télécharger le fichier
Dates and versions
hal-01698914 , version 1 (01-02-2018)
hal-01698914 , version 2 (16-04-2019)
Identifiers
  • HAL Id : hal-01698914 , version 1
Cite
Théophile Chaumont-Frelet, Frédéric Valentin. The MHM Method for the Helmholtz Equation. 2018. ⟨hal-01698914v1⟩
317 View
436 Download
Share
