Improvement of Multidisciplinary Integration in Design of Complex Systems by Implementing Knowledge-Based Engineering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chen Zheng
  • Fonction : Auteur
  • PersonId : 990163
Matthieu Bricogne
Julien Le Duigou
Benoît Eynard
Interface in one complex system represents the logical or physical relationship integrating the components of the complex system or the components with their environment. It plays a quite significant role to guarantee the components designed by the designers of different disciplines integrate correctly in order to achieve the multidisciplinary integration. This paper presents an interface knowledge base to capitalise the design data and rules related to the interfaces. A knowledge-based engineering (KBE) design methodology in which the interface knowledge base is implemented is then proposed to help the designers to improve the multidisciplinary integration during the detailed design phase of complex systems. This KBE design methodology is finally demonstrated by a case study based on a partial discharge (PD) detection system.
434860_1_En_9_Chapter.pdf (727.27 Ko) Télécharger le fichier
hal-01699697 , version 1 (02-02-2018)
Paternité
Chen Zheng, Matthieu Bricogne, Julien Le Duigou, Peter Hehenberger, Sandor Vajna, et al.. Improvement of Multidisciplinary Integration in Design of Complex Systems by Implementing Knowledge-Based Engineering. 13th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2016, Columbia, SC, United States. pp.89-98, ⟨10.1007/978-3-319-54660-5_9⟩. ⟨hal-01699697⟩
180 Consultations
176 Téléchargements
