An IoT Fueled DSS for MOL Marine Auxiliaries Management - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The producers of marine auxiliaries face the challenge, that they need to adapt their middle-of-life activities to the otherwise defined and often not well communicated schedules of the ships, which are carrying their products. This paper presents both the methodological approach to a solution and its prototypical implementation in a specific use case. The solution presented is utilizing the Internet of Things (IoT) and the data that is constantly being produced by the ships through the Automatic Identification System (AIS) to help overcome this problem.
434860_1_En_55_Chapter.pdf (543.33 Ko) Télécharger le fichier
hal-01699710 , version 1 (02-02-2018)
Paternité
Moritz Von Stietencron, Karl A. Hribernik, Carl Christian Røstad, Bjørnar Henriksen, Klaus-Dieter Thoben. An IoT Fueled DSS for MOL Marine Auxiliaries Management. 13th IFIP International Conference on Product Lifecycle Management (PLM), Jul 2016, Columbia, SC, United States. pp.621-630, ⟨10.1007/978-3-319-54660-5_55⟩. ⟨hal-01699710⟩
165 Consultations
225 Téléchargements
