Simulation of multiphase porous media flows with minimizing movement and finite volume schemes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Applied Mathematics Année : 2019
The Wasserstein gradient flow structure of the PDE system governing multiphase flows in porous media was recently highlighted in [C. Cancès, T. O. Gallouët, and L. Monsain-geon, Anal. PDE 10(8):1845–1876, 2017]. The model can thus be approximated by means of the minimizing movement (or JKO) scheme, that we solve thanks to the ALG2-JKO scheme proposed in [J.-D. Benamou, G. Carlier, and M. Laborde, ESAIM Proc. Surveys, 57:1–17, 2016]. The numerical results are compared to a classical upstream mobility Finite Volume scheme, for which strong stability properties can be established.
CGLM_preprint.pdf (7.86 Mo) Télécharger le fichier
hal-01700952 , version 1 (05-02-2018)
Clément Cancès, Thomas Gallouët, Maxime Laborde, Léonard Monsaingeon. Simulation of multiphase porous media flows with minimizing movement and finite volume schemes. European Journal of Applied Mathematics, 2019, 30 (6), pp.1123-1152. ⟨10.1017/S0956792518000633⟩. ⟨hal-01700952⟩
414 Consultations
158 Téléchargements
