Coercivity, hypocoercivity, exponential time decay and simulations for discrete Fokker- Planck equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Numerische Mathematik Année : 2020
In this article, we propose and study several discrete versions of homogeneous and inhomogeneous one-dimensional Fokker-Planck equations. In particular, for these dis-cretizations of velocity and space, we prove the exponential convergence to the equilibrium of the solutions, for time-continuous equations as well as for time-discrete equations. Our method uses new types of discrete Poincaré inequalities for a " two-direction " discretization of the derivative in velocity. For the inhomogeneous problem, we adapt hypocoercive methods to the discrete cases.
DHL.pdf (960.52 Ko) Télécharger le fichier
hal-01702545 , version 1 (06-02-2018)
Guillaume Dujardin, Frédéric Hérau, Pauline Lafitte-Godillon. Coercivity, hypocoercivity, exponential time decay and simulations for discrete Fokker- Planck equations. Numerische Mathematik, 2020, 144, ⟨10.1007/s00211-019-01094-y⟩. ⟨hal-01702545⟩
807 Consultations
384 Téléchargements
