Learning to Group Discrete Graphical Patterns - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2017
We introduce a deep learning approach for grouping discrete patterns common in graphical designs. Our approach is based on a convolutional neural network architecture that learns a grouping measure defined over a pair of pattern elements. Motivated by perceptual grouping principles, the key feature of our network is the encoding of element shape, context, symmetries, and structural arrangements. These element properties are all jointly considered and appropriately weighted in our grouping measure. To better align our measure with human perceptions for grouping, we train our network on a large, human-annotated dataset of pattern groupings consisting of patterns at varying granularity levels, with rich element relations and varieties, and tempered with noise and other data imperfections. Experimental results demonstrate that our deep-learned measure leads to robust grouping results.
zou_siga17_group.pdf (11.22 Mo) Télécharger le fichier
Format : Figure, Image
hal-01703062 , version 1 (07-02-2018)
  • HAL Id : hal-01703062 , version 1
Zhaoliang Lun, Changqing Zou, Haibin Huang, Evangelos Kalogerakis, Ping Tan, et al.. Learning to Group Discrete Graphical Patterns. ACM Transactions on Graphics, 2017, 11. ⟨hal-01703062⟩
317 Consultations
300 Téléchargements
