A test for assessing the goodness-of-fit of luminosity function models to magnitude-redshift data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monthly Notices of the Royal Astronomical Society Année : 2001
We propose a test which allows us to check whether a luminosity function model can account for the intrinsic luminosity distribution of a magnitude – redshift sample complete in apparent magnitude. No a priori assumptions are required concerning the redshift-space distribution of the sources, so neither the clustering nor an eventual evolution of the mean number density of the galaxies affects the conclusions of the goodness-of-fit test. The statistical efficiency of the test, if used as a fitting technique for estimating the best-fitting solution of a parametric luminosity function model, is comparable to the efficiency of standard maximum likelihood fitting techniques. The goodness-of-fit test presents however a major improvement compared with fitting techniques in general: the capacity to assess the adequacy of the proposed parametric model to the data. The computational implementation of this new test is straightforward. Its potential is illustrated on the Southern Sky Redshift Survey of da Costa et al.
328-4-1016.pdf (325.4 Ko) Télécharger le fichier
hal-01704643 , version 1 (28-01-2022)
Paternité
Stéphane Rauzy, Martin A. Hendry, Kenton d'Mellow. A test for assessing the goodness-of-fit of luminosity function models to magnitude-redshift data. Monthly Notices of the Royal Astronomical Society, 2001, 328 (4), pp.1016 - 1026. ⟨10.1046/j.1365-8711.2001.04864.x⟩. ⟨hal-01704643⟩
54 Consultations
22 Téléchargements
