Informational Texture Synthesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
Li-Yi Wei
  • Fonction : Auteur
Connelly Barnes
  • Fonction : Auteur
This paper presents a novel technique to embed messages into textures synthesized from tiles with boundary constraints. The messages are encoded in the choices that the synthesis algorithm normally makes at random during the synthesis process. Images embedding messages are not distinguishable from images that are not embedding any message. The random sequence seed used during synthesis can act as a password.
infotexsyn.pdf (161.45 Ko) Télécharger le fichier
hal-01706539 , version 1 (12-02-2018)
hal-01706539 , version 2 (14-02-2018)
hal-01706539 , version 3 (08-03-2018)
hal-01706539 , version 4 (28-06-2021)
  • HAL Id : hal-01706539 , version 2
Sylvain Lefebvre, Li-Yi Wei, Connelly Barnes. Informational Texture Synthesis. 2018. ⟨hal-01706539v2⟩
1491 Consultations
3942 Téléchargements
