A Method of Multi-perspective Assessment of Lean Management - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2017
Andreas Mueller
  • Function : Author
  • PersonId : 991418
Lean Management (LM) can harm corporations when unconditional implementation takes place. This paper proves that LM implementation brings negative side effects. Main reason for this can be stated as dysfunctional assessment of projects. Neither management control nor any other known method or mechanism can prevent side effects at present. As outcome of this paper a method for multi-perspective assessment is proposed, to resolve this problem.
456373_1_En_40_Chapter.pdf (128.75 Ko) Télécharger le fichier
Dates and versions
hal-01707296 , version 1 (12-02-2018)
Attribution
Identifiers
Cite
Andreas Mueller. A Method of Multi-perspective Assessment of Lean Management. IFIP International Conference on Advances in Production Management Systems (APMS), Sep 2017, Hamburg, Germany. pp.350-357, ⟨10.1007/978-3-319-66926-7_40⟩. ⟨hal-01707296⟩
123 View
81 Download
Share
