Two uncommon cases of Pneumococcal pyomyositis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue JMM Case reports Année : 2015
We report two new cases of pneumococcal pyomyositis managed at an inter-regional referral centre for bone and joint infections in the south of France. One of our patients had heterozygous sickle-cell disease, and the second had no apparent immunodeficiency. The pneumococcal pyomyositis was localized primarily to the psoas muscle and was complicated by hip arthroplasty infection in one of our cases. In the other case, it was localized to the abductor muscle, which has not been reported previously.
jmmcr000037.pdf (375.33 Ko) Télécharger le fichier
hal-01711104 , version 1 (16-02-2018)
Estelle Honnorat, Piseth Seng, Julie Finance, Benjamin Blondel, Andreas Stein. Two uncommon cases of Pneumococcal pyomyositis. JMM Case reports, 2015, 2 (4), ⟨10.1099/jmmcr.0.000037⟩. ⟨hal-01711104⟩
162 Consultations
83 Téléchargements
