One-way rotation of a molecule-rotor driven by a shot noise - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Nanoscale Année : 2014
Christian Joachim
The shot noise of a tunneling current passing through a molecule-motor can sustain a one-way rotation when populating the molecular excited states by tunneling inelastic excitations. We demonstrate that a ratchet-like ground state rotation potential energy curve is not necessary for the rotation to occur. A relative shift in energy difference between the maxima of this ground state and the minima of the excited states is the necessary condition to get to a unidirectional rotation. The rotor speed of rotation and its rotation direction are both controlled by this shift, indicating the necessity of a careful design of both the ground and excited states of the next generation of molecule-motors to be able to generate a motive power at the nanoscale.
C. Joachim Jorge Motor.pdf (993.22 Ko) Télécharger le fichier
hal-01712782 , version 1 (19-06-2018)
Jorge Echeverria, Serge Monturet, Christian Joachim. One-way rotation of a molecule-rotor driven by a shot noise. Nanoscale, 2014, 6 (5), pp.2793-2799. ⟨10.1039/c3nr05814j⟩. ⟨hal-01712782⟩
145 Consultations
177 Téléchargements
