Instance Optimal Decoding and the Restricted Isometry Property - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
In this paper, we study the preservation of information in ill-posed non-linear inverse problems, where the measured data is assumed to live near a low-dimensional model set. We provide necessary and sufficient conditions for the existence of a so-called instance optimal decoder, i.e. that is robust to noise and modelling error. Inspired by existing results in Compressive Sensing, our analysis is based on a (Lower) Restricted Isometry Property (LRIP), formulated in a non-linear fashion. We also provide a characterization for non-uniform recovery when the encoding process is randomly drawn, with a new formulation of the LRIP. We finish by describing typical strategies to prove the LRIP in both linear and non-linear cases, and illustrate our results by studying the invertibility of a one-layer neural network with random weights.
main.pdf (224 Ko) Télécharger le fichier
hal-01718411 , version 1 (27-02-2018)
hal-01718411 , version 2 (01-03-2018)
Nicolas Keriven, Rémi Gribonval. Instance Optimal Decoding and the Restricted Isometry Property. 2018. ⟨hal-01718411v1⟩
323 Consultations
237 Téléchargements
