Inferring inflection classes with description length - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Language Modelling Année : 2018
We discuss the notion of an inflection class system, a traditional ingredient of the description of inflection systems of nontrivial complexity. We distinguish systems of microclasses, which partition a set of lexemes in classes with identical behavior, and systems of macroclasses, which group lexemes that are similar enough in a few larger classes. On the basis of the intuition that macroclasses should contribute to a concise description of the system, we propose one algorithmic method for inferring macroclasses from raw inflectional paradigms, based on minimisation of the description length of the system under a given strategy of identifying morphological alternations in paradigms. We then exhibit classifications produced by our implementation on French and European Portuguese conjugation data and argue that they constitute an appropriate systematisation of traditional classifications. To arrive at such a convincing systematisation, it was crucial for us to use a local approach to inflection class similarity (based on pairwise comparisons of paradigm cells) rather than a global approach (based on the simultaneous comparison of all cells). We conclude that it is indeed possible to infer inflectional macroclasses objectively.
184-1460-1-PB.pdf (1.14 Mo) Télécharger le fichier
hal-01718879 , version 1 (27-02-2018)
  • HAL Id : hal-01718879 , version 1
Sacha Beniamine, Olivier Bonami, Benoît Sagot. Inferring inflection classes with description length. Journal of Language Modelling, 2018, 5 (3), pp.465-525. ⟨hal-01718879⟩
255 Consultations
271 Téléchargements
