Journal articles
Non-autonomous higher-order Moreau's sweeping process: Well-posedness, stability and Zeno trajectories
Bernard Brogliato 1
1 TRIPOP - Modélisation, simulation et commande des systèmes dynamiques non lisses
Inria Grenoble - Rhône-Alpes, LJK - Laboratoire Jean Kuntzmann
Abstract : In this article we study the higher-order Moreau's sweeping process introduced in [1], in the case where an exogenous time-varying function u(·) is present in both the linear dynamics and in the unilateral constraints. First we show that the well-posedness results obtained in [1] for the autonomous case, extend to the non-autonomous case when u(·) is analytic, after a suitable state transformation is done. Stability issues are discussed. The complexity of such nonsmooth non-autonomous dynamical systems is illustrated in a particular case named the higher-order bouncing ball, where trajectories with accumulations of jumps are exhibited. Examples from mechanics and circuits illustrate some of the results. The link with complementarity dynamical systems and with switching differential-algebraic equations is made.
Complete list of metadata
Cited literature [62 references]  Display  Hide  Download
https://hal.inria.fr/hal-01722772
Contributor : Bernard Brogliato Connect in order to contact the contributor
Submitted on : Monday, November 19, 2018 - 10:47:41 AM
Last modification on : Wednesday, October 27, 2021 - 5:31:11 AM
Long-term archiving on: : Wednesday, February 20, 2019 - 12:19:48 PM
File
Brogliato_EJAM.pdf
Identifiers
Collections
Citation
Bernard Brogliato. Non-autonomous higher-order Moreau's sweeping process: Well-posedness, stability and Zeno trajectories. European Journal of Applied Mathematics, Cambridge University Press (CUP), 2018, 29 (5), pp.941-968. ⟨10.1017/S0956792518000256⟩. ⟨hal-01722772v2⟩
Share
Metrics
Record views
389
Files downloads
1402
