New interface
Conference papers
3D Snap Rounding
Olivier Devillers 1 Sylvain Lazard 1 William Lenhart 2
1 GAMBLE - Geometric Algorithms and Models Beyond the Linear and Euclidean realm
Inria Nancy - Grand Est, LORIA - ALGO - Department of Algorithms, Computation, Image and Geometry
Abstract : Let $\mathcal{P}$ be a set of $n$ polygons in $\mathbb{R}^3$, each of constant complexity and with pairwise disjoint interiors. We propose a rounding algorithm that maps $\mathcal{P}$ to a simplicial complex $\mathcal{Q}$ whose vertices have integer coordinates. Every face of $\mathcal{P}$ is mapped to a set of faces (or edges or vertices) of $\mathcal{Q}$ and the mapping from $\mathcal{P}$ to $\mathcal{Q}$ can be done through a continuous motion of the faces such that (i) the $L_\infty$ Hausdorff distance between a face and its image during the motion is at most 3/2 and (ii) if two points become equal during the motion, they remain equal through the rest of the motion. In the worst case, the size of $\mathcal{Q}$ is $O(n^{15})$ and the time complexity of the algorithm is $O(n^{19})$ but, under reasonable hypotheses, these complexities decrease to $O(n^{5})$ and $O(n^{6}\sqrt{n})$.
Document type :
Conference papers
Complete list of metadata
https://hal.inria.fr/hal-01727375
Contributor : Olivier Devillers Connect in order to contact the contributor
Submitted on : Friday, March 9, 2018 - 10:31:41 AM
Last modification on : Saturday, November 19, 2022 - 3:59:02 AM
Long-term archiving on: : Sunday, June 10, 2018 - 1:29:01 PM
snap.pdf
Identifiers
Citation
Olivier Devillers, Sylvain Lazard, William Lenhart. 3D Snap Rounding. Proceedings of the 34th International Symposium on Computational Geometry, Jun 2018, Budapest, Hungary. pp.30:1 - 30:14, ⟨10.4230/LIPIcs.SoCG.2018.30⟩. ⟨hal-01727375⟩
Share
Metrics
Record views
235
Files downloads
279
