Semi-automatic phonetic labelling of large corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
The aim of the present paper is to present a methodology to semi-automatically label large corpora. This methodology is based on three main points: using several concurrent automatic stochastic labellers, decomposing the labelling of the whole corpus into an iterative refining process and building a labelling comparison procedure which takes into account phonologic and acoustic-phonetic rules to evaluate the similarity of the various labelling of one sentence. After having detailed these three points, we describe our HMM-based labelling tool and we describe the application of that methodology to the Swiss French POLYPHON database.
Mots clés
euro97.pdf (95.73 Ko) Télécharger le fichier
hal-01727539 , version 1 (09-03-2018)
  • HAL Id : hal-01727539 , version 1
Odile Mella, Dominique Fohr. Semi-automatic phonetic labelling of large corpora . EUROPSPEECH'97 - Fifth European conference on speech communication and technology, Sep 1997, Rhodes, Greece. ⟨hal-01727539⟩
155 Consultations
37 Téléchargements
