Semi-automatic phonetic labelling of large corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1997
The aim of the present paper is to present a methodology to semi-automatically label large corpora. This methodology is based on three main points: using several concurrent automatic stochastic labellers, decomposing the labelling of the whole corpus into an iterative refining process and building a labelling comparison procedure which takes into account phonologic and acoustic-phonetic rules to evaluate the similarity of the various labelling of one sentence. After having detailed these three points, we describe our HMM-based labelling tool and we describe the application of that methodology to the Swiss French POLYPHON database.
Mots clés
euro97.pdf (95.73 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
hal-01727539 , version 1 (09-03-2018)
  • HAL Id : hal-01727539 , version 1
Odile Mella, Dominique Fohr. Semi-automatic phonetic labelling of large corpora . EUROPSPEECH'97 - Fifth European conference on speech communication and technology, Sep 1997, Rhodes, Greece. ⟨hal-01727539⟩
155 Consultations
37 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
