Presenting the Nénufar Project: a Diachronic Digital Edition of the Petit Larousse Illustré - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
This paper presents the Nénufar project, which aims to make several successive (free of copyright up to 1948) editions of the French Petit Larousse Illustré dictionary available in a digitised format. The corpus of digital editions will be made publicly available via a web-based querying interface, as well as distributed in a machine readable format, TEI-LEX0.
presenting-nenufar-project (2).pdf (2.2 Mo) Télécharger le fichier
hal-01728328 , version 1 (10-03-2018)
  • HAL Id : hal-01728328 , version 1
Hervé Bohbot, Francesca Frontini, Giancarlo Luxardo, Mohamed Khemakhem, Laurent Romary. Presenting the Nénufar Project: a Diachronic Digital Edition of the Petit Larousse Illustré. GLOBALEX 2018 - Globalex workshop at LREC2018, May 2018, Miyazaki, Japan. pp.1-6. ⟨hal-01728328⟩
870 Consultations
342 Téléchargements
