Journal articles
Multilevel strategies for parametric shape optimization in aerodynamics
Badr Abou El Majd 1 Jean-Antoine Desideri 1 Régis Duvigneau 2
1 OPALE - Optimization and control, numerical algorithms and integration of complex multidiscipline systems governed by PDE
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
2 ACUMES - Analysis and Control of Unsteady Models for Engineering Sciences
Abstract : The essential numerical features of multilevel strategies developed for parametric shape optimization are reviewed. These methods employ nested parameterization supports of either shape, or shape deformation, and the classical process of degree elevation resulting in exact geometrical data transfer from coarse to fine representations. The algorithms mimick classical multigrid strategies and are found very effective in terms of convergence acceleration. In particular, for a drag reduction problem involving a three-dimensional Eulerian transonic flow simulated by an unstructured-grid finite-volume method, the complete algorithm is found to be noticeably superior to the natural algorithm simply based on progressive degree elevation.
Complete list of metadata
Cited literature [24 references]  Display  Hide  Download
https://hal.inria.fr/hal-01730520
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Tuesday, March 13, 2018 - 3:23:53 PM
Last modification on : Thursday, August 4, 2022 - 4:52:48 PM
Long-term archiving on: : Thursday, June 14, 2018 - 2:04:18 PM
File
opale-remn.pdf
Identifiers
  • HAL Id : hal-01730520, version 1
Citation
Badr Abou El Majd, Jean-Antoine Desideri, Régis Duvigneau. Multilevel strategies for parametric shape optimization in aerodynamics. Revue Européenne de Mécanique Numérique/European Journal of Computational Mechanics, Hermès / Paris : Lavoisier 2008, 17 (1-2). ⟨hal-01730520⟩
Share
Metrics
Record views
101
Files downloads
217
