Study of hard-soft magnetic ferrite films prepared by pulsed laser deposition - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Physics: Conference Series Année : 2014
Soft magnetic Mg 0.1 Ni 0.3 Zn 0.6 Fe 2 O 4 and hard magnetic BaFe 12 O 19 bulk nanocrystalline ferrites were synthesized using the sol-gel auto-combustion method, and were used as targets to deposit soft-hard thin films by the pulsed laser deposition (PLD) method. Various soft-hard thin films with different preparation conditions were deposited on Si (100) substrate, which can be effectively utilized to get better magnetic properties. The prepared films were characterized by the X-ray diffraction (XRD), atomic force microscopy (AFM) and magnetic measurements. XRD confirms the presence of soft and hard phases in the thin films. Coercivity of the prepared films ranges from 1.67 to 2.66 kA/m. AFM images show clustering of grains at the film surface with a characteristic columnar growth.
Satalkar_2014.pdf (1.65 Mo) Télécharger le fichier
hal-01734965 , version 1 (15-03-2018)
M. Satalkar, S. N. Kane, A. Ghosh, S. Raghuvanshi, P. Tapkir, et al.. Study of hard-soft magnetic ferrite films prepared by pulsed laser deposition. Journal of Physics: Conference Series, 2014, 534 (1), pp.012043. ⟨10.1088/1742-6596/534/1/012043⟩. ⟨hal-01734965⟩
119 Consultations
64 Téléchargements
