The impact of stereotyped and non-stereotyped brand genders on cross-gender extension evaluations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Marketing Management Année : 2017
This research proposes to introduce the concept of stereotype to definebrand gender and to make a new contribution on the analysis of cross-gender extension evaluation. The results of an experiment, made on two product categories and considering the two possible directions of these extensions – from men to women and from women to men – reveal that the perceived fit between the cross-gender extension and the brand is more positive when the brand gender is non-stereotyped and, surprisingly, when the brand extends from the female to the male market. The interaction effect suggests also that the impact of the cross-gender extension direction is more important in the case of a brand with a non-stereotyped gender. Those results challenge previous research. A concluding discussion lays out recommendations for business.
JMM Stereotypes and CGE (10.10).pdf (577.9 Ko) Télécharger le fichier
hal-01735491 , version 1 (23-03-2018)
Nathalie Veg-Sala. The impact of stereotyped and non-stereotyped brand genders on cross-gender extension evaluations. Journal of Marketing Management, 2017, 5, pp.60 - 74. ⟨10.15640/jmm.v5n2a6⟩. ⟨hal-01735491⟩
294 Consultations
387 Téléchargements
