Privacy Preserving Record Matching Using Automated Semi-trusted Broker - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ibrahim Lazrig
  • Fonction : Auteur
  • PersonId : 1022673
Indrakshi Ray
  • Fonction : Auteur
  • PersonId : 885868
Toan Ong
  • Fonction : Auteur
  • PersonId : 1022674
Michael Kahn
  • Fonction : Auteur
  • PersonId : 1022675
Nora Cuppens
  • Fonction : Auteur
  • PersonId : 863921
In this paper, we present a novel scheme that allows multiple data publishers that continuously generate new data and periodically update existing data, to share sensitive individual records with multiple data subscribers while protecting the privacy of their clients. An example of such sharing is that of health care providers sharing patients’ records with clinical researchers. Traditionally, such sharing is performed by sanitizing personally identifying information from individual records. However, removing identifying information prevents any updates to the source information to be easily propagated to the sanitized records, or sanitized records belonging to the same client to be linked together. We solve this problem by utilizing the services of a third party, which is of very limited capabilities in terms of its abilities to keep a secret, secret, and by encrypting the identification part used to link individual records with different keys. The scheme is based on strong security primitives that do not require shared encryption keys.
340025_1_En_7_Chapter.pdf (1.22 Mo) Télécharger le fichier
hal-01745819 , version 1 (28-03-2018)
Paternité
Ibrahim Lazrig, Tarik Moataz, Indrajit Ray, Indrakshi Ray, Toan Ong, et al.. Privacy Preserving Record Matching Using Automated Semi-trusted Broker. 29th IFIP Annual Conference on Data and Applications Security and Privacy (DBSEC), Jul 2015, Fairfax, VA, United States. pp.103-118, ⟨10.1007/978-3-319-20810-7_7⟩. ⟨hal-01745819⟩
124 Consultations
136 Téléchargements
