Classification of Player Roles in the Team-Based Multi-player Game Dota 2 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Computer games are big business, which is also reflected in the growing interest in competitive gaming, the so-called electronic sports. Multi-player online battle arena games are among the most successful games in this regard. In order to execute complex team-based strategies, players take on very specific roles within a team. This paper investigates the applicability of supervised machine learning to classifying player behavior in terms of specific and commonly accepted but not formally well-defined roles within a team of players of the game Dota 2. We provide an in-depth discussion and novel approaches for constructing complex attributes from low-level data extracted from replay files. Using attribute evaluation techniques, we are able to reduce a larger set of candidate attributes down to a manageable number. Based on this resulting set of attributes, we compare and discuss the performance of a variety of supervised classification algorithms. Our results with a data set of 708 labeled players see logistic regression as the overall most stable and best performing classifier.
371182_1_En_9_Chapter.pdf (825.5 Ko) Télécharger le fichier
hal-01758447 , version 1 (04-04-2018)
Paternité
Christoph Eggert, Marc Herrlich, Jan Smeddinck, Rainer Malaka. Classification of Player Roles in the Team-Based Multi-player Game Dota 2. 14th International Conference on Entertainment Computing (ICEC), Sep 2015, Trondheim, Norway. pp.112-125, ⟨10.1007/978-3-319-24589-8_9⟩. ⟨hal-01758447⟩
193 Consultations
2180 Téléchargements
